It is currently Wed Apr 17, 2024 6:57 pm
 Post subject: Oil Pan and Timing Cover
PostPosted: Thu Jun 23, 2022 11:14 am
Car Model: 1962 Dodge Dart 330 Sedan
Getting ready to reassemble my 62' Slant 6 and wanted some wisdom from the experienced on ways to make sure that I don't have leaks from the oil pan and/or the timing cover. Much thanks - gpk1961
PostPosted: Thu Jun 23, 2022 9:17 pm
Car Model: 1975 Dodge D100
Check the Articles page. Lots of cool stuff over there.
Here’s a link:
https://www.slantsix.org/articles/gaske ... n-seal.htm
I recommend Doc’s book too.
https://www.amazon.com/Chrysler-Slant-S ... 153&sr=8-1
I used this book as a guide and was able to complete my first slant rebuild with confidence.
Good luck with your project!
1975 Dodge D100 225 c.i., HEI, Parallel Offenhauser, Motorcraft 2150, 904 auto, 9.25" 3.55:1
PostPosted: Fri Jun 24, 2022 5:23 pm
Thanks! I just found and ordered that book...good recommendation and thanks for the article - I forget to check the articles page.
I am gathering parts and have the long block on the engine stand, ready to get started.
GPK1961
PostPosted: Mon Jun 27, 2022 6:21 am
Is the engine out and on a stand? if so It goes together easiest with the timing cover assembled first.
- Start with a helping of RTV - I like Permatex Grey (but any flavor will probably do)- placed on all of the cork/paper side wall junctions to the rubber ends - especially in the corners.
- Set the pan on / Start all bolts loose but do not tighten or torque to spec yet.
Let the RTV "flash off" for 4-24 Hours
- Final Torque the pan Down
- It's possible you may still have a leaker in the Lower RF Front Corner.. By the Timing Cover.
- You can RTV over the outside of the Pan to Timing cover Junction here if you want.
I am sure others have some sage advice and techniques that they prefer and may chime in here.
Best of luck.
PostPosted: Mon Jun 27, 2022 3:39 pm
Thanks Greg - yes it is on the engine stand. I have the timing cover ready to go and I am waiting for an oil pickup tube.
It had very minor leaks before the rebuild and I am hoping to keep it that way! Thanks for the tips! gpk1961
Users browsing this forum: No registered users and 68 guests
cron
