Slant Six Forum https://slantsix.org/forum/ |
Torque for Spark Plug Tubes? https://slantsix.org/forum/viewtopic.php?f=19&t=54209 |
Author: | 63valconvert [ Thu Jan 02, 2014 10:59 am ] |
Post subject: | Torque for Spark Plug Tubes? |
Yes, this is going on the assumption that there's no such thing as a stupid question. Curious, though, what kind of torque I should use for tightening the spark plugs in a spark plug-tubed head? I always seem to have leaks there, new seals or not. Thanks! |
Author: | carlherrnstein [ Thu Jan 02, 2014 12:47 pm ] |
Post subject: | |
Ahhh good ol drool tubes. I have seen very few that didn't leak. If I'm not mistaken you have the crush gasket type spark plugs. Normally I just turn them 1/4 turn after I cant turn them by hand I'm sure that's not the "correct" way to do it, but it has worked so far. |
Author: | crater [ Thu Jan 02, 2014 1:13 pm ] |
Post subject: | |
For all my spark plugs I've always hand tightened then just a little bit further with a breaker bar or torque wrench. Don't forget to remove the washer from the spark plug before installation. |
Author: | 63valconvert [ Thu Jan 02, 2014 6:21 pm ] |
Post subject: | Thanks! |
Thanks, guys. I always do the washer thing. Maybe I'm going a little tight. I'll try finger tight and then a bit tighter with a socket. |
Author: | DusterIdiot [ Thu Jan 02, 2014 6:27 pm ] |
Post subject: | Pinkie tight... |
Quote: I'll try finger tight and then a bit tighter with a socket.
My grandfather always told me that if I didn't have a torque wrench on a mopar to finger tight them in place, then use the 3/8" ratchet and plug socket and use your pinkie on the handle to cinch it in place (it's about 10 ft lbs...of course I have built up my muscles since then, so I have to watch it or I'll do 35 ft lbs with the twist of the wrist...) |
Author: | SlantSteve [ Thu Jan 02, 2014 9:37 pm ] |
Post subject: | |
I know some people don't recommend it,but I use a smear of silicone around the o rings to seal them up,works fine for me. As for torque,all good advise in above posts,cheers. |
Author: | Pierre [ Thu Jan 02, 2014 11:25 pm ] |
Post subject: | |
I doubt too tight is your source of leaks. I don't see what the big deal with using silicon at that point is. Heck why not just a fat bead of silicon with no ring? It's not under pressure, just drip. Just have to be careful removing them next time so none falls in. I generally have good luck with new seals. Use fancy plugs so you don't have to be fussing with them as often. Seems they seep once they get repositioned. |
Author: | SlantSteve [ Fri Jan 03, 2014 12:11 am ] |
Post subject: | |
Pierre wrote: I doubt too tight is your source of leaks.
I don't see what the big deal with using silicon at that point is. Heck why not just a fat bead of silicon with no ring? I'm with you,not sure what the big deal is,done it all the time as a standard deal when fitting them,but there was a post a while back ,can't really recall the points against it,but some were pretty passionate about not doing it. At the end of the day it works! |
Author: | Reed [ Fri Jan 03, 2014 12:12 am ] |
Post subject: | |
I always put a bead of RTV sealant around the drool tubes when I install them with new gaskets. Torque on spark plugs? Snug. |
Author: | ILMopars [ Fri Jan 03, 2014 8:16 pm ] |
Post subject: | |
FSM says 30 ft.-lbs., right? |
Author: | wjajr [ Sat Jan 04, 2014 1:24 pm ] |
Post subject: | |
Quote: FSM says 30 ft.-lbs., right?
Same as my 1967 copy... |
Author: | Diggs [ Sat May 14, 2022 3:32 pm ] |
Post subject: | Re: Torque for Spark Plug Tubes? |
I’m not surprised so many people call the spark plug tubes ‘drool tubes’. 30 ft. Pounds is needed to adequately pull the tube tight enough for the gasket to actually seal against the head. 30 ft. Pounds would be a lot if these were aluminum heads however that isn’t too much torque for a steel cylinder head like on the slant. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
