Slant Six Forum https://slantsix.org/forum/ |
Oversized head gasket https://slantsix.org/forum/viewtopic.php?t=55572 |
Author: | 1930 [ Tue Jun 10, 2014 3:08 am ] |
Post subject: | Oversized head gasket |
Is anyone here aware of these being avail. I was told on another forum that oversized bores were avail for the slant |
Author: | Rick Covalt [ Tue Jun 10, 2014 3:17 am ] |
Post subject: | |
Yes the Permaseal Head Gasket from Australia is a 3.66 bore head gasket. Rick |
Author: | 1930 [ Wed Jun 11, 2014 3:19 am ] |
Post subject: | |
Quote: Yes the Permaseal Head Gasket from Australia is a 3.66 bore head gasket.
Thanks, yes evidently there is no oversized gasket avail here in the states. I have called around
Rick |
Author: | DusterIdiot [ Wed Jun 11, 2014 5:25 am ] |
Post subject: | Why? |
Quote: yes evidently there is no oversized gasket avail here in the states.
The felpro and Victor Reinz are 3.5 bore size...considering that the stock slant is a 3.4" bore that will get you through all the overbores a street motor needs (20,30,40,60,80...and the long rods at .45), the only reason to go past that is for maximum performance...with an over bore past .100 you have to pick and check your blocks and other prep has to occur that may not be so street friendly.Any reason you'd need that kind of over bore in a truck? |
Author: | Rick Covalt [ Wed Jun 11, 2014 1:08 pm ] |
Post subject: | |
Quote: Thanks, yes evidently there is no oversized gasket avail here in the states.
Yes, I ordered the last group buy on the gaskets that came from Australia. I think I ordered 20 of them and the shipping alone was over $200. Not sure what the shipping would be on one or two gaskets. Rick |
Author: | Dart270 [ Wed Jun 11, 2014 1:32 pm ] |
Post subject: | |
How big do you need? ACL was making a gasket that was 3.54" or so. Aussie Permaseal (now called Endurotec) is the 3.66" one. Lou |
Author: | 1930 [ Wed Jun 11, 2014 2:45 pm ] |
Post subject: | Re: Why? |
Quote: Quote: yes evidently there is no oversized gasket avail here in the states.
The felpro and Victor Reinz are 3.5 bore size...considering that the stock slant is a 3.4" bore that will get you through all the overbores a street motor needs (20,30,40,60,80...and the long rods at .45), the only reason to go past that is for maximum performance...with an over bore past .100 you have to pick and check your blocks and other prep has to occur that may not be so street friendly.Any reason you'd need that kind of over bore in a truck? I think the poster was confused a bit but its all good. |
Author: | 1930 [ Wed Jun 11, 2014 2:46 pm ] |
Post subject: | |
Quote: How big do you need? ACL was making a gasket that was 3.54" or so. Aussie Permaseal (now called Endurotec) is the 3.66" one.
Thanks for the tip but the stock bore size will be just fine.
Lou |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
