It is currently Sun May 11, 2025 7:00 am
PostPosted: Fri Mar 17, 2023 9:09 am
Car Model: 1987 D 100 225 Slant 6
Hey All
I have been through the 1987 Service manual and cannot find any good info on the AC belt routing as well as part numbers.
I bought a 1987 D 100 with the AC compressor in place, but the smog pump is missing and of course has no belt. I actually ordered a remanufactured air pump. The pulley to the air pump was on the floor of the truck so I will be able to put it on the smog pump.
Does that then make the smog pump the belt tensioner for that belt? Does anyone have a diagram?
PostPosted: Fri Mar 17, 2023 5:11 pm
Found it!
https://www.slantsix.org/forum/viewtopi ... bvZqqKyCgA
