It is currently Tue Dec 01, 2020 7:07 am
 Post subject: Fuel cell
PostPosted: Sat Nov 21, 2020 4:16 pm
3 Deuce Webber
Instead of 1963 tank I’d run fuel cell under floor pan any ideas ?
Pros con street strip
12 gallon
Race tech issues ?
1963 Plymouth Valiant Wagon
 Post subject: Re: Fuel cell
PostPosted: Sat Nov 21, 2020 11:12 pm
To be legal in Tech it will have to have a sheet metal cover around it. Also, you may find it hangs down a lot lower than a standard tank. Other than that, I can't think of any reason you can't do it. :mrgreen:
PostPosted: Mon Nov 23, 2020 8:16 am
I have a 5 Gal Fuel Cell in the back.
I Welded in some metal to cover the sump below the spare tire / trunk well.
It will need a ground wire from the cell onto the chassis itself.
I will also need a Vent that goes through the floor to the outside atmosphere.
Greg Ondayko
