It is currently Fri Oct 15, 2021 1:49 pm
PostPosted: Tue Oct 12, 2021 7:53 am
If you had to choose 4 out o the 6 cylinders to record data in which ones would you use?
I would Think 1, 2, 4,6, then interpolate that data to assume tuning strategies for 3,5 from data provided from cyl's 2,4?
Is it even a worry if you have ITB's ?
Whaddya Think?
Greg Ondayko
PostPosted: Tue Oct 12, 2021 10:07 am
Nice question, Greg.
For symmetry, you want 1 from each symmetric pair. So, you could do 1, 2, 3 or 1, 5, 3 and then roll the dice for the last one. Cyl 1 tends to run hottest due to the coolant path, so best to read that one for sure as a worst/hottest case. I would probably pick 6 as the 4th one so I could get a cooler version of cyl 1.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Tue Oct 12, 2021 11:34 am
Maybe the 4th one after the collector.
Might give a clue if something was too far off with one of the un-monitored cylinders.
EDIT: my aging brain read this as AFR not EGT. So, nevermind...
PostPosted: Tue Oct 12, 2021 5:49 pm
Can you get 2 extra sensors and plumb all 6?
Then you can figure out which 4 make the most sense...........
PostPosted: Tue Oct 12, 2021 6:56 pm
I don't think so On the system I was looking at.. its either 4 or 8.
Greg Ondayko
PostPosted: Tue Oct 12, 2021 10:43 pm
Only use 4 at a time
PostPosted: Wed Oct 13, 2021 8:16 am
Car Model: 1954 Dodge C1-B8
If I had to do this I would use cylinders 1,3, 5 and 6. #1 for the same reason Lou stated, it's hottest, and it's also the furthest uphill. #3 as it and #4 have the straightest 'look' at a single carburetor, but you probably only need to sample one of them. #5 (or #2) as it's in the middle of a group of 3. #6 as it''s the farthest down hill and has the coldest combustion chamber. This is essentially what you settled on except I chose #5 instead of #2 as plenum manifolds can sometimes run the rear cylinders rich and this setup samples 2/3 of the front and rear.
PostPosted: Wed Oct 13, 2021 8:41 am
Cool, thanks for the insight.
Greg Ondayko
PostPosted: Wed Oct 13, 2021 2:23 pm
Is this going on the race car Greg? Dat der be addin some weight!! :D
12.80 @ 102.88
PostPosted: Wed Oct 13, 2021 3:48 pm
Yes and yes. I have more areas to slice and dice that I have not even touched yet.
Greg Ondayko
PostPosted: Thu Oct 14, 2021 6:31 am
Car Model: 1966 Dodge Dart
That is how I would handle this if I had to - but any individual cylinder could develop a problem. If I were going for EGT, I'd spring for a system that could watch all the cylinders.
Matt Cramer
PostPosted: Thu Oct 14, 2021 6:59 am
Is there such a system that would datalog / interface with MS3?
If so I might be swayed to use that one instead of the original stand alone that I was shopping on.
Greg Ondayko
PostPosted: Thu Oct 14, 2021 8:09 am
This?
--> https://www.diyautotune.com/product/can-egt-8-channel-thermocouple-interface/
PostPosted: Thu Oct 14, 2021 9:56 am
Yep. Cool. Thanks pc..
I was looking for that.. more channels, better price.
Greg Ondayko
PostPosted: Thu Oct 14, 2021 3:34 pm
Use the extra 2 channels..........
One just before the turbo, one after...............
:mrgreen:
