It is currently Sat Jun 29, 2024 12:28 am
 Post subject: POINT RACE RULES
PostPosted: Sat Mar 02, 2002 10:17 pm
I pulled what i could find useing search.Is there a set of classes & Rules to use.I would hate to pull 10 hrs.or so and not be able to Race because of something I did or did not do,etc.......arthur
coinjockey@webtv.net
PostPosted: Sun Mar 03, 2002 8:30 am
(User Above) wrote:
: I pulled what i could find useing search.Is
: there a set of classes & Rules to use.I
: would hate to pull 10 hrs.or so and not be
: able to Race because of something I did or
: did not do,etc.......arthur
The rules to run the car are pretty simple:
1) Get to a SSRN SL6 points event with a SL6 powered car.
2) Anything goes with the engine and the car set-up *As Long As* it's SL6 powered and the car passes the *track's* tech inspection for the time index it runs. (Basic NHRA / IHRA safety rules)
3) Have Fun! - Win Money! (if you can 'beat-out' all those other racers)
We want to keep things easy so anyone can get involved.
You need to send for a set of SSRN Point Series "How points are awarded" rules, that is, if you plan to go to a number of races and try for some of the $3,000.00 to be awarded to the season end, top 10 total points finishers.
