It is currently Mon Apr 15, 2024 11:19 pm
PostPosted: Wed Nov 02, 2022 10:29 am
Hello, Are there LH / RH Versions of the DCOE Carbs?
I am going to be getting a set for a project and they are advertised as such.
is it just where the throttle Lever Mounts?
Thank you DCOE Sages.
PostPosted: Wed Nov 02, 2022 10:51 am
Hi Greg
To my knowledge the carbs are the same.
They sell right and left hand throttle levers.
If you are buying them just make sure you have your linkage figured out.
I have purchased a bunch of levers, links, rod end bearings etc to fit my setup.
What I found was the left and right levers had a slightly different lenght.
SO they don't swing in quite the same arc.
Give me a call, maybe I can save you some fustrations.
PostPosted: Wed Nov 30, 2022 7:48 am
Sorry, I didn't see this earlier? But I think if you get RH and LH linkages from the same manufacturer they should be the same length/arc. Mine use all RH linkages, but Ryan's uses both LH and RH and they both look the same to me. Good luck.
