It is currently Fri Apr 19, 2024 11:08 am
PostPosted: Fri Nov 25, 2022 11:34 am
Got the old leaf spring off, but I can' figure a way to remove the rear hanger/bushing... The nuts seem to be inaccessible.... or are there captured nuts behind those bolts?
Help, pls.
PostPosted: Fri Nov 25, 2022 12:54 pm
IIRC, the bolts just thread into the frame.
PostPosted: Fri Nov 25, 2022 7:13 pm
Yes they should just bolt into the frame box there.
If you got a wrench/socket on 'em and they are spinning then you might be having to cut the bolt heads off.
Users browsing this forum: No registered users and 15 guests
