It is currently Sun Apr 27, 2025 4:09 pm
PostPosted: Wed May 15, 2024 6:20 am
Car Model: 68 Barracuda
How do you all feel about this bit of bad work on the pump flange. Its at the top of the trans, looks like a bilt was used to push out the pump
Usable?
PostPosted: Wed May 15, 2024 6:40 am
There is no picture here.
Depends if it is just the pump bushing that is goobered up or if the damage got into the pump rotor housing / bearing support area or not.
I would just get a whole new front pump assembly from A and A transmission in Camby Indiana and be done with the whole thing.
PostPosted: Wed May 15, 2024 9:25 am
PostPosted: Wed May 15, 2024 9:28 am
Trying to post image. Its a mark on the trans housing near on the top by a bolt hole where it seems a bolt was used to force the pump out of the trans.
PostPosted: Wed May 15, 2024 9:35 am
PostPosted: Wed May 15, 2024 10:53 am
Still ain't coming up.
Sounds like it's the trans case itself not the pump
I have an engine/ trans core place by me I've bought internal trans parts from before. Planetaries, pumps, drums etc.
Near the top/ so not by the fluid port holes where fluid passes from pump to case... I think I know what you're talking about, and approximately where...
There are 2 pump housing holes tapped the next size over what the bolts are that hole the pump in.. meant for a slide hammer to get the pump out. Is this divot you mentioned in line with e pump mount hole?
If the aluminum is displaced or raised from the flat surface I'd dress it down flat the best I could without creating a crater and chase that pump mount hole, put the gasket on the pump and the outer o ring, and send it.
PostPosted: Wed May 15, 2024 2:57 pm
That's exactly where the problem is. Thanks for the advice.
Users browsing this forum: Semrush [Bot] and 2 guests
