Slant Six Forum https://slantsix.org/forum/ |
Manual Guy Building a 904. https://slantsix.org/forum/viewtopic.php?f=20&t=34824 |
Author: | Greg Ondayko [ Sat Apr 11, 2009 6:32 pm ] |
Post subject: | Manual Guy Building a 904. |
Hello Auto Transmission Sages. I will be building a 904 for racing next year. All of the internal stuff on the rebuild seems quite simple - Clutches, steels, bands, drums etc. My questions relate more to Valve bodies, Fluid choice, and Most important, Torque Converters. What do you recommend for these?? I think Eventually I would like to use a Reverse pattern manual valve body as this will be a full out racer with no street use. This might have to wait as budget allows. The cam is going to be the Schenider 296-06F - 296* dur Intake and 306* exhaust. 108 * lobe separation with approximate power range 3200-6200 RPM Transmission in question will be a 69 slant 6 904. 4.10 or 4.30 Gears out back with 26-28" Slicks. Thanks, Greg |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
