Slant Six Forum https://slantsix.org/forum/ |
What's the Shudder from https://slantsix.org/forum/viewtopic.php?f=20&t=38191 |
Author: | JeffDavis [ Thu Dec 03, 2009 7:34 am ] |
Post subject: | What's the Shudder from |
I all. I have a '64 Signet w/push button auto. I get a shudder when ever there's torque on the tranny like going up hill or accelerating on level surface or up hill. Doesn't seem to be a problem going down hill or when not accelerating. Stopped and talked to a tranny. guy and he says it's not torque converter shudder because Chrysler didn't use clutches in the t/c until something like 1968. I've got new Ujoints so and fresh fluid and filter in the tranny. Any ideas ?? Also, whats the recommended fluid to use in one of these A904's ? Thanks, Jeff |
Author: | sandy in BC [ Thu Dec 03, 2009 9:33 am ] |
Post subject: | |
Look for a new tranny guy. Im not saying its a converter (although it prolly is) Im saying tranny dude is wrong to rule it out..... |
Author: | SlantSixDan [ Thu Dec 03, 2009 10:54 am ] |
Post subject: | |
Often this condition is caused by a worn-out front ball-and-trunnion front universal joint housing. You have new U-joints; exactly what was done to the front U-joint? New housings are available, but they are costly and not easy to source; the better fix is the cross-and-roller conversion. |
Author: | hellion_locdogg [ Sat Feb 13, 2010 12:09 pm ] |
Post subject: | |
Oh thank god, someone else has experienced the same drama I've had for the last TWO yrs... Check list - timing, u-joints, trans, compression, tires, torque converter..... |
Author: | 66aCUDA [ Sun Feb 14, 2010 7:13 am ] |
Post subject: | |
So what did you do to fix the shudder? Frank |
Author: | JeffDavis [ Mon Feb 15, 2010 4:57 am ] |
Post subject: | |
Sorry to say that I haven't done anything. Was told by a different tranny guy that he believes it's the clutches in the tranny. Car is setting in the garage for now waiting to yank the tranny for a rebuild. Wife recently got laid off so that puts a big dent in the fun money |
Author: | BIGFISH [ Thu Feb 25, 2010 10:28 am ] |
Post subject: | |
Is it the tranny mount? Did you check the ball & trunion for slop? I had the pin in the ball and trunion shift over just a little and caused a vibe when I was accelerating. |
Author: | SlantSixDan [ Thu Feb 25, 2010 6:23 pm ] |
Post subject: | |
JeffDavis wrote: Sorry to say that I haven't done anything. Was told by a different tranny guy that he believes it's the clutches in the tranny. Car is setting in the garage for now waiting to yank the tranny for a rebuild.
Uh…how 'bout trying the (much) easier, (much) less costly stuff before going through the pain and expense of a transmission rebuild? Just sayin'. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
