It is currently Fri Jul 05, 2024 12:32 pm
 Post subject: What's the Shudder from
PostPosted: Thu Dec 03, 2009 7:34 am
I all. I have a '64 Signet w/push button auto. I get a shudder when ever there's torque on the tranny like going up hill or accelerating on level surface or up hill. Doesn't seem to be a problem going down hill or when not accelerating. Stopped and talked to a tranny. guy and he says it's not torque converter shudder because Chrysler didn't use clutches in the t/c until something like 1968. I've got new Ujoints so and fresh fluid and filter in the tranny. Any ideas ?? Also, whats the recommended fluid to use in one of these A904's ?
Jeff
PostPosted: Thu Dec 03, 2009 9:33 am
Look for a new tranny guy.
Im not saying its a converter (although it prolly is) Im saying tranny dude is wrong to rule it out.....
PostPosted: Thu Dec 03, 2009 10:54 am
Often this condition is caused by a worn-out front ball-and-trunnion front universal joint housing. You have new U-joints; exactly what was done to the front U-joint? New housings are available, but they are costly and not easy to source; the better fix is the cross-and-roller conversion.
PostPosted: Sat Feb 13, 2010 12:09 pm
Oh thank god, someone else has experienced the same drama I've had for the last TWO yrs...
Check list - timing, u-joints, trans, compression, tires, torque converter.....
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Sun Feb 14, 2010 7:13 am
So what did you do to fix the shudder?
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Feb 15, 2010 4:57 am
Sorry to say that I haven't done anything. Was told by a different tranny guy that he believes it's the clutches in the tranny. Car is setting in the garage for now waiting to yank the tranny for a rebuild. Wife recently got laid off so that puts a big dent in the fun money :(
PostPosted: Thu Feb 25, 2010 10:28 am
Is it the tranny mount? Did you check the ball & trunion for slop? I had the pin in the ball and trunion shift over just a little and caused a vibe when I was accelerating.
'64 Barracuda
PostPosted: Thu Feb 25, 2010 6:23 pm
Uh…how 'bout trying the (much) easier, (much) less costly stuff before going through the pain and expense of a transmission rebuild?
Just sayin'.
