Slant Six Forum https://slantsix.org/forum/ |
Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package https://slantsix.org/forum/viewtopic.php?f=20&t=65283 |
Page 1 of 11 |
Author: | AndyZ [ Wed Sep 02, 2020 5:56 am ] |
Post subject: | Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package |
Ram Clutches will be making me a dual clutch with pocketed flywheel for the slant and I am seeking others that may want in on this production run. Here is a link to what they will be making: https://ramclutches.com/force-95-dual-disc/ The price will be $950. Possibly less if we get enough buyers. |
Author: | Greg Ondayko [ Wed Sep 02, 2020 6:28 am ] |
Post subject: | Re: ***Looking for interested parties in a clutch/flywheel package from Ram Clutches |
I am in Can we spec 1x23 or 1.0625x10? What is the flywheel weight? Greg |
Author: | Dan-o [ Wed Sep 02, 2020 7:57 am ] |
I'm interested. If this all comes together; I just need to get a T-5! |
Author: | Greg Ondayko [ Wed Sep 02, 2020 8:30 am ] |
Dan, thats the easy part! We are doing all the hard work for ya! Greg |
Author: | Dan-o [ Wed Sep 02, 2020 9:52 am ] |
Riding high on the shoulders of giants! |
Author: | Greg Ondayko [ Wed Sep 02, 2020 10:23 am ] |
If you say so brotha' Greg |
Author: | Joshie225 [ Wed Sep 02, 2020 11:16 am ] |
I'll take one with an aluminum flywheel and organic discs with a 1"-23 spline. If that's troublesome then a steel flywheel. |
Author: | Rick Covalt [ Wed Sep 02, 2020 2:14 pm ] |
Will talk to Ryan and see if he is interested. |
Author: | Rob Simmons [ Wed Sep 02, 2020 3:07 pm ] |
I may be a player in this. Gotta have options for my estate sale. |
Author: | slantzilla [ Wed Sep 02, 2020 10:05 pm ] |
This for the 122 tooth flywheel? |
Author: | Dart270 [ Thu Sep 03, 2020 9:02 am ] |
Yes, assuming this is stock slant 122 tooth fly, then I am in for one set for sure, and perhaps two. I will go aluminum, but maybe steel for the 2nd one. I would need the disc(s) to have the Ford T5 spline (1 1/6" X 10). If I get two, I may request the T56 6 spd spline for a 2nd one. I saw your post about weights. Those are fairly heavy, but I guess you are able to support much more HP. My alum fly and McLeod B&B setup is 30 lbs all in, and under 40 lbs for a stock cast iron (20 lb) fly. Thanks!! Lou |
Author: | Greg Ondayko [ Thu Sep 03, 2020 9:25 am ] |
slantzilla wrote: This for the 122 tooth flywheel? Dennis, I believe so.. viewtopic.php?f=7&t=65281 But I will let Andy Z be the definitive Source of correct Info. Greg |
Author: | slantzilla [ Thu Sep 03, 2020 10:53 am ] |
Thanks Greg. At this time I will get in as a "maybe". |
Author: | AndyZ [ Fri Sep 04, 2020 6:45 am ] |
Yes, this is for the 122 tooth flywheel. Likely all will be large hole so Greg can make some $ on this. |
Author: | slantzilla [ Fri Sep 04, 2020 9:42 am ] |
Thank you! |
Page 1 of 11 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
