It is currently Wed Apr 24, 2024 5:12 am
PostPosted: Sat Mar 27, 2021 4:12 pm
Car Model: 1964 Plymouth Valiant Signa 200 Convertible
I am swapping in a rebuilt 904 into my 64 Signet 200 Convertible. Stock 225 with split exhaust manifolds , Clifford Intake, Holley 390 and HEI. I need recommendations on what to get for a torque converter as far as going with a stock rebuilt one or a higher stall converter and a good place to get one. Thanks in advance ! Pat.
PostPosted: Sun Mar 28, 2021 5:28 am
Are you using the PB trans? Is the engine a 67 or earlier, or the 68 up? Makes a difference in the converter. How you use the car, and what you are looking for will make a difference in the converter.
66 Valiant Signet 225 nitrous
PostPosted: Sun Mar 28, 2021 8:43 am
Original 64 225, Yes staying with push button trans.
Just a cruiser. Thank you
PostPosted: Mon Mar 29, 2021 5:51 am
If you have a little money to spend, call Andre at Edge racing converters and have him build you a 2200-2400 stall for that engine/trans combo. It should be about as efficient as stock and will give you more oomph off the line.
Home of Slant6-powered fun machines
PostPosted: Mon Mar 29, 2021 8:04 am
x2
Users browsing this forum: No registered users and 17 guests
