7.25" driveshaft to 8.75" rear end U-joint sizes
https://slantsix.org/forum/viewtopic.php?f=20&t=66035
Page 1 of 1
Author:  Daddiojoe [ Fri Jun 18, 2021 5:42 pm ]
Post subject:  7.25" driveshaft to 8.75" rear end U-joint sizes
I did a search and couldn't find this info, so does anybody know what size U-joint I will need when using the old 7.25" driveshaft and a new 8.75" rear?
I understand that the size for each axis of the U-joint will be different.
Joe
Author:  Doctor Dodge [ Fri Jun 18, 2021 7:20 pm ]
Post subject:  Re: 7.25" driveshaft to 8.75" rear end U-joint sizes
Chrysler basically used 2 different sized u-joints during the time SL6 engines were in production.
The "small" version, with inner "C" clips, found on the 7 1/4 is called a 7260 u-joint. The larger version is the 7290.
8 3/4 axles used both types so you will need to measure to find the size on your replacement 8 3/4.
There are special conversion u-joints made to fit small to large or visa-versa but truth is, your 7 1/4 driveshaft will be too long to mate to any 8 3/4 so change the drive shaft yoke to the needed size, when shortening it.
Author:  Greg Ondayko [ Sat Jun 19, 2021 4:55 am ]
Here is a handy chart containing info as doc had referenced:
https://www.dennysdriveshaft.com/c974_u ... _size.html
Author:  Daddiojoe [ Sat Jun 19, 2021 6:30 pm ]
THANKS GUYS! I lucked out and have the same diameter U-joint on each axis.
Doc--you mentioned shortening. That is the next step. Is there a chart out there that shows driveshaft lengths?
Never mind--found it with a Google search.
Joe
