Slant Six Forum https://slantsix.org/forum/ |
Early 170 engine crank register mod advise needed https://slantsix.org/forum/viewtopic.php?f=20&t=66177 |
Author: | lgu32 [ Thu Sep 09, 2021 9:06 pm ] |
Post subject: | Early 170 engine crank register mod advise needed |
I have early 170 engine and late model 904. There is a fitment problem with converter hub. As the converter is custom piece (small diameter, high stall) I like to keep as is. So I have onlys choice to ask machinist to made my small register 170 crank to perfect fit. I have found a machinist to do it. I am pretty sure that has done before several times. I have calculated there is enough material to do it. Just to the inner hole to 1.81” and add an outer ring for flex plate centering (1.96”/2.16”) Please advice me to topics where this is discussed before. (I am overseas. Slant parts are not laying all around. Was a job to catch 170 bottom end which is not at biggest overbore and ”end”. Now I have a good project engine). |
Author: | Doctor Dodge [ Fri Sep 10, 2021 3:23 pm ] |
Post subject: | Re: Early 170 engine crank register mod advise needed |
Machine the counter-bore out to the larger size and use the early flex plate (small bore size) and everything works fine. DD ![]() |
Author: | Greg Ondayko [ Fri Sep 10, 2021 4:30 pm ] |
Awesome mod Doc! Thanks for Sharing. Greg |
Author: | lgu32 [ Sat Sep 11, 2021 3:03 am ] |
Thanks! |
Author: | lgu32 [ Sat Sep 18, 2021 8:55 pm ] |
Doctor Dodge wrote: Machine the counter-bore out to the larger size and use the early flex plate (small bore size) and everything works fine. DD ![]() One more question. What is the needed size for re-machined counterbore? Is it 1.81" (46,0mm) or 1.815" (46,1mm)? |
Author: | Doctor Dodge [ Mon Sep 20, 2021 5:03 pm ] |
1 13/16 inches = 1.8125 Best to measure the hub on the torque converter and add .002 for clearance. DD |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
