It is currently Mon Apr 15, 2024 10:40 pm
PostPosted: Thu Jan 26, 2023 2:03 pm
I was getting ready to put another slant in my ute .
Checked to see if the early converter would fit the early crankshaft (small pocket)
It will not fit , the diameter of the pilot on the rear of the converter is slightly larger .
It is 1mm / 3/64 of a inch larger in diameter than the crankshaft pocket .
I know it is a early converter as i had it on another engine with the larger pocket crankshaft .
I got a bushing from Pat Blais to use on that crankshaft .
Is there a difference between manual and automatic early crankshafts ?
Is there a way to ream(special tool) the pocket on the early crankshaft out slightly without taking it out of the engine ?
Has anybody else experienced this ?
Cheers , Greg
DRIVE IT,DON'T HIDE IT
PostPosted: Fri Jan 27, 2023 1:05 pm
I have another 2 early crankshafts here on the bench .
The torque converter slides easily into both .
This has me bugged .
PostPosted: Fri Jan 27, 2023 1:08 pm
I wonder if it was a crankshaft that had a stick transmission and they did not drill the torque converter pocket to size?
Home of Slant6-powered fun machines
