It is currently Thu Apr 18, 2024 8:06 pm
PostPosted: Wed Aug 03, 2022 9:39 am
I have an A904 automatic slant six, column shift, 1967 dart. Recently, when I'm in reverse it'll kick out of R and into N. It seems to be when I turn the steering wheel while backing up. Is this something in the steering column or perhaps the shift linkage at the tranny?
I'll figure it out, but I was just wondering what first impressions are here, if anyone has seen this - usually your guys' intuition and experience is spot on and saves us time!
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Wed Aug 03, 2022 2:06 pm
I would assume its the column to transmission adjustment.
Its easy to adjust and fix. Perhaps the service manual has the procedure.
PostPosted: Wed Aug 03, 2022 5:01 pm
Possibly broken motor/transmission mount.
PostPosted: Wed Aug 03, 2022 5:30 pm
Good call. Could be one of those too!
PostPosted: Sun Aug 07, 2022 8:40 am
Thanks guys, its not a broken mount, so OK the obvious is most likely, I'll check it out, thank you.
Users browsing this forum: No registered users and 18 guests
