It is currently Mon Jun 24, 2024 6:42 am
PostPosted: Wed Sep 28, 2022 10:41 pm
Car Model: 1966 2D Dart
My SG slips. It is now opened and seem to be rebuildable with some machining and shimming. However the spider gears - two small in the little axle are worn. Are those available as spares? Do open diff version have same parts there?
1966 Dart. 170 cu.in. 200 rwhp.
PostPosted: Thu Sep 29, 2022 1:33 pm
I would have to check part numbers. The clutch type 7 1/4 SG's have 4 spider gears, and those are different then the gears for the open 7 1/4
66 Valiant Signet 225 nitrous
PostPosted: Thu Sep 29, 2022 10:16 pm
Please check if you can. Could it be possible that for example 8.75" has had same gears there?
And if someone has a set of good used gears free I am interested to buy them.
PostPosted: Sun Oct 02, 2022 6:12 pm
I can't locate those gears in the parts manuals. The only 7 1/4 differential gears I can locate are for the open, or the clutch type SG. Those are different from each other. To be honest, I have never seen a cone type 7 1/4 SG.
PostPosted: Mon Oct 03, 2022 4:58 am
Ok and thanks. It will be rebuilt with gears it have in. As soon it is gone the whole axle will be replaced with another which has better availability for parts. A Toyota Hi-Lux axle... has same 4.1 gear ratio as this one.
Users browsing this forum: No registered users and 23 guests
