It is currently Sun May 05, 2024 3:01 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Thu Mar 14, 2002 7:13 pm
Ok, i got the valiant running! It turns out the distributor was set incorrectly, the rotor was pointing towards the fenderwell and i repositioned it and it fired up! i took off the valve cover and it was really sludged up. I went and got a gasket, and adjusted the valves correctly and that got rid of the idle problem, and it also fixed a miss in the engine. it runs really smooth and i can't wait to take it up and down the street tommorrow and see how the transmission shifts etc. Thanks for all your support and help. I am looking to add a little power to it so i might add a super six later on down the road.
ksjo923@hotmail.com
PostPosted: Fri Mar 15, 2002 12:22 pm
Thanks for the up-date, glad to hear you "stuck with it" and got the car running well.
(User Above) wrote:
: Ok, i got the valiant running! It turns out the
: distributor was set incorrectly, the rotor
: was pointing towards the fenderwell and i
: repositioned it and it fired up! i took off
: the valve cover and it was really sludged
: up. I went and got a gasket, and adjusted
: the valves correctly and that got rid of the
: idle problem, and it also fixed a miss in
: the engine. it runs really smooth and i
: can't wait to take it up and down the street
: tommorrow and see how the transmission
: shifts etc. Thanks for all your support and
: help. I am looking to add a little power to
: it so i might add a super six later on down
: the road.
