It is currently Fri May 29, 2026 11:47 am
 Post subject: Dual fuel injection
PostPosted: Fri Oct 05, 2018 12:35 pm
Car Model: Monaco
Has anyone seen or done a dual carb fuel injection? I currently have a dual two barrel setup(not on car yet) was wondering what option u had for fuel delivery
 Post subject: Re: Dual fuel injection
PostPosted: Sun Oct 07, 2018 1:28 am
Car Model: 1966 2D Dart
The one I have built for /6 is close to "true dual". I have 6 injectors in one group, 2 barrel throttle body and all the feedback for ECU (MAP, O2) has taken from cylinders 1-2-3. 4-5-6 will work like "slave".
So just get 2 identical throttle bodies, sync them and do the control either from front of rear group of cylinders with control system you like to use. I had my own design but the same will work with almost all control systems.
PostPosted: Sun Oct 07, 2018 3:07 am
I am not sure what you mean by "dual carb"? Are you talking about throttle bodies or?
PostPosted: Sun Oct 07, 2018 7:30 am
https://www.shop.cliffordperformance.ne ... 01M225.htm Like this I quess.
PostPosted: Sun Oct 07, 2018 10:41 am
Car Model: 1964 Dart 270
I have seen an International Harvester engine with dual tbi. Think the company that did it was Hamilton Fuel Injection.
http://www.binderplanet.com/forums/inde ... lt.120966/
That one is two one barrels, I think its 670 cfm between the two but I'm not positive. You could do two of the 2bbl units but would be overkill for sure.
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
