Slant Six Forum https://slantsix.org/forum/ |
Littile trick from the past, https://slantsix.org/forum/viewtopic.php?f=28&t=27790 |
Page 1 of 2 |
Author: | wjajr [ Wed Mar 12, 2008 6:19 am ] |
Post subject: | Littile trick from the past, |
I just remembered an odd thing my first 270 V8 from collage days would do. How I don't recall how I discovered this quirk. Or, why I still remember it, I'll leave that diagnoses for the next alzheimer's clinic visit... With a stock electrical system, and the ignition in the off position: Turn on the radio, four way flashers, and step on the brake. Hold this position for a short while, and the radio will play when the lights flash. |
Author: | Brian [ Wed Mar 12, 2008 8:06 am ] |
Post subject: | |
Author: | argentina-slantsixer [ Wed Mar 12, 2008 9:00 am ] |
Post subject: | |
did it all the time or just when UFO's where around, or car was near rockwell? ![]() |
Author: | SlantSixDan [ Wed Mar 12, 2008 9:35 am ] |
Post subject: | |
Do you still have the fender tag from that car? Check for option code A51 (Hat pkg, aluminum foil, all passengers) ![]() |
Author: | wjajr [ Wed Mar 12, 2008 10:26 am ] |
Post subject: | |
No tin foil hats needed, it was a hardtop, and after it was the 1970's. Now that I have a rag top, I will be raiding the pantry for some HD Reynold's Wrap to keep in the trunk... safety first. |
Author: | DusterIdiot [ Wed Mar 12, 2008 7:10 pm ] |
Post subject: | Rlmao... |
Quote: Check for option code A51
Uhhhh... "Crown Roof Two Tone Package" ?!??!?!?!?! I think A81... "Simulated Convertible Roof Two Tone Package" would be better.... -D.Idiot |
Author: | SlantSixDan [ Wed Mar 12, 2008 7:25 pm ] |
Post subject: | Re: Rlmao... |
DusterIdiot wrote: Quote: Check for option code A51 Uhhhh... "Crown Roof Two Tone Package" ?!??!?!?!?! Myeaaah...it was my lame attempt at an "Area 51" joke. |
Author: | Andy's GT [ Wed Mar 12, 2008 10:37 pm ] |
Post subject: | |
boooooooooooooooooo ![]() |
Author: | knuckledown [ Sat Mar 15, 2008 5:14 pm ] |
Post subject: | |
I remember a trick from my college days too. Step on the brake, turn off the lights, turn on the radio and remove her top! ![]() |
Author: | bbbbbb9 [ Sat Mar 15, 2008 5:57 pm ] |
Post subject: | Re: Littile trick from the past, |
wjajr wrote: I just remembered an odd thing my first 270 V8 from collage days would do.
How I don't recall how I discovered this quirk. Or, why I still remember it, I'll leave that diagnoses for the next alzheimer's clinic visit... With a stock electrical system, and the ignition in the off position: Turn on the radio, four way flashers, and step on the brake. Hold this position for a short while, and the radio will play when the lights flash. Was it only when a guy named Dusty Desks was with you and you guys "scored"? |
Author: | argentina-slantsixer [ Sat Mar 15, 2008 6:29 pm ] |
bbbbbb9 wrote: wjajr wrote: I just remembered an odd thing my first 270 V8 from collage days would do. How I don't recall how I discovered this quirk. Or, why I still remember it, I'll leave that diagnoses for the next alzheimer's clinic visit... With a stock electrical system, and the ignition in the off position: Turn on the radio, four way flashers, and step on the brake. Hold this position for a short while, and the radio will play when the lights flash. Was it only when a guy named Dusty Desks was with you and you guys "scored"? way back in the day, it wasn't "dusty desk" it was "clean schoolbench" |
Author: | argentina-slantsixer [ Sun Mar 16, 2008 8:33 am ] |
Post subject: | |
knuckledown wrote: I remember a trick from my college days too.
Step on the brake, turn off the lights, turn on the radio and remove her top! ![]() that rings a bell for sure! ![]() ![]() |
Author: | SlantSixDan [ Sun Mar 16, 2008 9:21 am ] |
Post subject: | |
Author: | bbbbbb9 [ Sun Mar 16, 2008 9:50 am ] |
Post subject: | |
Sorry Dan Sounds to me like someone grabbed the flasher hot wire for the radio ho |
Author: | SlantSixDan [ Sun Mar 16, 2008 10:09 am ] |
Post subject: | |
You can get all kinds of bizarre electrical feedback behaviour when the hazard flashers are turned on, because they are the (usually cheaply-done) junction of a circuit with always-live feed — the flashers — and a circuit with ignition-on feed — the turn blinkers. This is particularly true if there've been non-stock additions, subtractions, or modifications of the car's wiring. |
Page 1 of 2 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
