It is currently Fri Oct 04, 2024 2:39 pm
 Post subject: HEI Question
PostPosted: Tue Sep 17, 2013 7:37 am
So I was looking at the wiring diagram and noticed it was powered off the alternator stud through a relay. I have a relay and running that way is not an issue. My question, is it okay to power off the alternator stud? My headlight relays are clear across the car powered off the battery so I would rather not run it that way.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Tue Sep 17, 2013 7:47 am
You don't have to power it from the alternator. It's just a really convenient spot to get full voltage and keep the wire run short.
PostPosted: Tue Sep 17, 2013 7:49 am
Thank you I wanted a shorter wire closer to the install point.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
