It is currently Sun May 05, 2024 9:32 am
PostPosted: Mon Jul 20, 2020 5:17 pm
So i had a distributor that i was going to use for my HEI upgrade/lean burn delete on my 85 D100. I pulled it out today to find that it was pretty grungy and it looks like the shaft is bent slightly. On top of that it came out of a 76 Aspen so i'm sure it isnt the best choice for a truck. Does anyone have any recommendations on a new or rebuilt dizzy that would suit my needs? I see that rockauto has some but im sure they are not the best options.
Thanks in advance!
Currently a 1976 /6 with no car to put it in, hoping to build a hot rod around it.
PostPosted: Mon Jul 20, 2020 6:08 pm
Actually the 1976 distributor would have been good to use overall and a good core to rebuild/recurve... especially if a 3874598...
Check Old Car Parts NW for a 3874598 as an OEM replacement with known curve...anything on Rockauto will be a reman and you will have
a lot of work to figure out what they sold you...
Users browsing this forum: No registered users and 21 guests
