It is currently Wed Apr 24, 2024 4:26 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Apr 28, 2021 5:48 pm
Car Model: 1983 DODGE D150 SLANT SIX 225CI AUTO
Tried 2 new and one used all do the same thing. So for now as we needed the truck we put a 1/8 inch shim under the dizzy works fine for now lol
PostPosted: Fri Apr 30, 2021 9:57 am
well that lasted a day. Back to no start. Now we have spark and fuel. Wondering if the timing chain have ever been replaced? 383,000 miles on it ...prob not. Dont wont to put much more work into it and NO mort $$ Its POS anyway
PostPosted: Fri Apr 30, 2021 11:38 am
Have you checked the reluctuor/pickup gap in the distributor? Where did you get the distributor? Remanufactured distributors available at parts stores these days are highly suspect due to poor remanufacturing protocols. Does the distributor shaft have side-to-side play? Don't know why you would object to spending a small amount of money fixing your truck instead of spending more money to get a different vehicle.
PostPosted: Sat May 01, 2021 11:48 am
Well into it for about $1000 now lol Anyway new cap and rotor (found a small defect in old one 300 miles on it but it was a cheap one. Put it back at TDC this morn, reset the dizz, and with dizz fully seated and it started. Next up new timing chain set. I swear the chain is slipping. How else could the dizz move out of time??
PostPosted: Sat May 01, 2021 12:20 pm
2 ideas. One is the # or times you've had things in and out, maybe didn't tighten something as much as you thought?
And 2. I had this happen to me once. 79 d150 with the slant.
I left the house, got a 1/2 a mile away and had a backfire. Crank and crank and crank, no fire. I coasted into a farm field entrance just to get out of the road. Something led me to pull the distributor on the spot, the dist gear was chewed up. I took another car to the parts store, and got a gear. Put it in, fired once, then backfired, then crank with no response.
Chewed up another gear. When I pulled the distributor the 2nd time the drive gear on the cam was in a position where I could see the cause. All the teeth on one side of the cam gear were sheared. With my brother's help we got the truck home with moms car and a chain. I found another slant and swapped engines. I wish I would have just put a cam in that original engine as the replacement ended up being a bad oil burner. Which led me to find and build up a (non slant) engine for that truck.
