It is currently Thu Jan 20, 2022 12:56 pm
PostPosted: Thu Nov 11, 2021 2:00 am
Car Model: 1966 2D Dart
I am building a 170 cuin slant for turbo use. I will use Felpro gasket as they are widely available.
HOW MUCH BOOST a stock compression slant can handle without any special rings on the block/head surface?
E85 fuel and EFI with closed loop O2 sensor => well controllable burning process without detonation.
1966 Dodge Dart under construction. 225=> 170 turbo (MPI).
PostPosted: Thu Nov 11, 2021 5:03 am
It all depends on the tuneup and avoiding detonation. My guess is around 12-16 psi.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Jan 14, 2022 4:12 am
Ok I'll try stay below that point. The T3/4 I have has 0.8 bar setting as stock. It is about 10-11 PSI.
Here it is pre-installed. There was room enough for everything thanks to slanted engine.
PostPosted: Fri Jan 14, 2022 5:04 am
Looks like nice work so far. Glad to see you have EFI installed. Best wishes for the rest of the build!
PostPosted: Fri Jan 14, 2022 5:45 am
This car was my test bench for I build an analog fuel injection system long time ago. It has now replaced with Maxxecu (ECU).
I have 4.10 gears and 26" tires and 5500 rpm at the end of 1/4 mile. I thought a 170 is safe for more RPM but I have to get the torque kept ...
Turbo setup will have 7 (seven) fuel injectors. All are equal in size...
But where to put the 7th?
PostPosted: Sat Jan 15, 2022 2:15 am
Anti-lag for the 7th injector?? :twisted:
PostPosted: Sat Jan 15, 2022 5:38 am
Trying use E85 pre spray for cooling. When sprayded just after turbo output it meet the hot air where ethanol will boil - similar to methanol & water mix spray but this uses same fuel (only E85 with 70-85% ethanol) as the 6 sequential injectors.
PostPosted: Sat Jan 15, 2022 6:36 am
Are you using a fuel sensor? Here in the states, the ethanol percentage varies greatly. E-85 is a "max" of 85 %. It can be a lot less.
66 Valiant Signet 225 nitrous
PostPosted: Sat Jan 15, 2022 8:42 am
I am planning to add a flex fuel sensor because the availability of E85 is not good at all areas. For E85 ethanol percentage the continuous O2 sensor feedback is enough. I am using a AFR table as the target and it works well.
