Slant Six Forum https://slantsix.org/forum/ |
Aussiespeed Supercharger Manifold being cast https://slantsix.org/forum/viewtopic.php?f=30&t=56967 |
Author: | John1972 [ Thu Jan 22, 2015 12:24 am ] |
Post subject: | Aussiespeed Supercharger Manifold being cast |
Just read the update on the Aussiespeed website, slant supercharger manifold now being cast. Is to suit 142/144 Weiand using small block chevy length drive, and will have adopters for other such as 3/71, 4/71 & Eatons etc. Good to see Aussie company supporting the slant guys. I've been patiently waiting a long time for this ![]() https://www.facebook.com/superchargerki ... 79/?type=1 ![]() |
Author: | Dart270 [ Thu Jan 22, 2015 5:03 am ] |
Post subject: | |
Looks nice. If you have an "in" with them, I would highly suggest increasing the runner cross-sectional area. Many of us have tried these intakes on naturally aspirated motors and they run out of breath around 5000-5500. A quick swap to a Clifford 4bbl gets you a bunch of top end power. The main difference I can see that might produce this is the small runner area... I have tried the long and the short runner and they both run out of breath up high. Thanks, Lou |
Author: | John1972 [ Thu Jan 22, 2015 9:47 am ] |
Post subject: | |
Hi Lou. Would the forced induction negate the smaller runner issue of make it worse in your opinion? |
Author: | Dart270 [ Thu Jan 22, 2015 10:00 am ] |
Post subject: | |
I have less experience/knowledge about that, but the turbo folks I know have wanted large runner areas and large-ish plenums. Looks like that intake has the large plenum part... Lou |
Author: | Slanteast [ Thu Jan 22, 2015 10:53 am ] |
Post subject: | |
Good day, Lou how does the Offy intake compare with the Clifford? any difference above 5000? Those engines on the Aussie website look awesome!!! Thanks Derek |
Author: | Dart270 [ Thu Jan 22, 2015 11:25 am ] |
Post subject: | |
Offy is better below 4500 or so. Clifford is definitely better above that, assuming you have a motor that can make power up there (good flowing head, higher comp, med/large cam, looser rotating/recip assembly, etc). All things being equal, headwork w/bigger valves will get you the biggest gains out of anything. Lou |
Author: | John1972 [ Thu Jan 22, 2015 1:21 pm ] |
Post subject: | |
If this manifold does have a larger plenum for the blower, is there enough material in the runners for someone to work their magic? |
Author: | kesteb [ Thu Jan 22, 2015 9:39 pm ] |
Post subject: | |
I have tried both, with the same engine setup, and the Clifford was the better manifold. In my opion, the Offy is no better then a supersix manifold, with the exception that you can run 4v carb. |
Author: | Dart270 [ Fri Jan 23, 2015 6:57 am ] |
Post subject: | |
Yes, there is material in the runners, but why not cast it bigger to begin with? Lou |
Author: | Slanteast [ Fri Jan 23, 2015 8:03 am ] |
Post subject: | |
Hey, when you say tried them both on the same engine. Did the engine have a lot of mods? Headwork, big cam etc? hp? Has anyone else had similar results with the Clifford vrs Offy? I also was wondering if the triple Webbers would be a gain from either a Clifford or Offy 4brl? Has anyone made that upgrade on a built engine without other major changes and got good results? I ve been wondering that ever since I got the Slant bug. Appreciate any and all comments. Thanks Derek |
Author: | kesteb [ Fri Jan 23, 2015 11:30 pm ] |
Post subject: | |
Yes, home ported head, OS valves, 8.75 compresion, erson 270 cam, dutra manifolds, 500 avs, yada, yada... The only change was the manifold swap. The Clifford was better. |
Author: | se7enine [ Wed Feb 11, 2015 12:30 pm ] |
Post subject: | |
The manifold is now on Aussiespeed's website. $795 http://www.aussiespeedshop.com/product/ ... ld-as0042/ |
Author: | 1974duster kev [ Wed Feb 11, 2015 8:23 pm ] |
Post subject: | |
Pretty sweettttttt Kev |
Author: | Dart270 [ Thu Feb 12, 2015 10:03 pm ] |
Post subject: | |
Yes, tried on heavily modified engine. Lou |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
