It is currently Wed Aug 17, 2022 9:36 am
PostPosted: Sat Aug 31, 2019 3:53 am
Car Model: plymouth duster
are original rods 225 + twr forged piston strong enough for between 15 and 20 psi of boost?
Thanks in advance for reply
PostPosted: Sat Aug 31, 2019 6:29 am
If your tuneup is good (no detonation) and the rods are rebuilt correctly with good (ARP) bolts, then they should be fine. RPMs will kill motors too, and you do not need to turn RPMs with a boosted motor to make power. Stay under 5500 or so.
"You mean you still have a Slant 6 in that thing?"
