It is currently Thu Aug 18, 2022 6:14 am
PostPosted: Sun Sep 01, 2019 1:48 am
Car Model: plymouth duster
which carb 2 barrel for turbo project with intercooler ?
someone tell me that if i use my weber 32/36 with a intercooler , i will have problem of fuel that beads with cold air.
PostPosted: Sun Sep 01, 2019 4:13 pm
A Weber 32/36 doesn't flow enough air for a naturally aspirated 225 and it won't flow enough fuel for a turbocharged one. Don't worry about fuel vaporization. Even with intercooling the intake charge is still well above ambient temperature. If you're determined to use a 2bbl I would use a 350 CFM Holley with a solid float and lots of other mods.
