It is currently Sun Jan 17, 2021 12:35 am
PostPosted: Tue Nov 19, 2019 6:08 am
Car Model: 1966 Dodge Dart
One thing I noticed on the dyno is that I get a lot of oil blown out the dipstick tube under boost. Has anyone ever modified the dip stick with some sort of retainer to hold it in place when crankcase pressure goes up?
Matt Cramer
PostPosted: Tue Nov 19, 2019 10:26 am
Car Model: 1965 Plymouth Barracuda, 1954 Dodge C1-B8
I've used a piece of fuel line pushed over the tube. It's not a positive lock, but it helps. There's not much surface area for the pressure to act on so not much force.
Why do you think the crankcase pressure isn't going out the breather?
PostPosted: Tue Nov 19, 2019 11:29 am
It's definitely going out the breather too, but the dipstick tube had been pushed upward noticably on the dyno pulls. Fuel line sounds like a good option for now - thanks for the suggestion.
Matt Cramer
