Slant Six Forum https://slantsix.org/forum/ |
Anyone ever modify a dipstick to be a locking type? https://slantsix.org/forum/viewtopic.php?f=30&t=64232 |
Author: | MadScientistMatt [ Tue Nov 19, 2019 6:08 am ] |
Post subject: | Anyone ever modify a dipstick to be a locking type? |
One thing I noticed on the dyno is that I get a lot of oil blown out the dipstick tube under boost. Has anyone ever modified the dip stick with some sort of retainer to hold it in place when crankcase pressure goes up? |
Author: | Joshie225 [ Tue Nov 19, 2019 10:26 am ] |
Post subject: | Re: Anyone ever modify a dipstick to be a locking type? |
I've used a piece of fuel line pushed over the tube. It's not a positive lock, but it helps. There's not much surface area for the pressure to act on so not much force. Why do you think the crankcase pressure isn't going out the breather? |
Author: | MadScientistMatt [ Tue Nov 19, 2019 11:29 am ] |
Joshie225 wrote: I've used a piece of fuel line pushed over the tube. It's not a positive lock, but it helps. There's not much surface area for the pressure to act on so not much force. Why do you think the crankcase pressure isn't going out the breather? It's definitely going out the breather too, but the dipstick tube had been pushed upward noticably on the dyno pulls. Fuel line sounds like a good option for now - thanks for the suggestion. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
