It is currently Fri Feb 26, 2021 1:18 am
 Post subject: Turbo with AC ?
PostPosted: Sat Dec 14, 2019 8:16 am
Car Model: 76 Aspen
New to turbos but want to do it to the slant six. But the big problem is that I need AC in warm weather. Has this been done ? Thanks.
 Post subject: Re: Turbo with AC ?
PostPosted: Wed Dec 18, 2019 12:27 am
Yes, I have A/C and run a turbo. But my build is very different than most turbo builds. I have a rear mounted turbo under the car behind the rear axle. Left me with plenty of room for A/C. For most conventional turbo builds, the only available space for A/C would be to use a manual steering box and try to mount it where the power steering unit usually resides. Definitely would have to run a modern Sanden type compressor due to the tight quarters there.
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Wed Dec 18, 2019 2:37 am
https://www.youtube.com/channel/UClJr9M ... hbA/videos
Check his Duster build. I believe there is turbo, AC and powersteering.
PostPosted: Wed Dec 18, 2019 11:30 am
Sam Powell did it on his 69 Dart with a Buick GN turbo and sanden compressor. PS too, IIRC. Try searching this site. He has passed away and the car was sold.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Wed Dec 18, 2019 11:49 am
Power steering is easier with a modern pump and relocated reservoir like many modern cars use.
Gref
Greg Ondayko
