Slant Six Forum https://slantsix.org/forum/ |
Modify single barrel intake for supercharger https://slantsix.org/forum/viewtopic.php?t=65136 |
Author: | Pgbarrow [ Tue Jul 21, 2020 12:15 pm ] |
Post subject: | Modify single barrel intake for supercharger |
Hi guys, I have an opportunity to pick up a single barrel carb intake and could use a 20,000 foot answer on this. Is is reasonably possible to modify the manifold to accept a supercharger out of an old Riviera or whatever else I can scrounge from a junkyard? Sincerely, Paul Barrow |
Author: | Charrlie_S [ Tue Jul 21, 2020 12:53 pm ] |
Post subject: | Re: Modify single barrel intake for supercharger |
If you mean from a Buick or Pontiac turbocharger, the answer is yes. Several have done it, including myself with a Corvair turbo. |
Author: | Pgbarrow [ Tue Jul 21, 2020 3:04 pm ] |
Thanks guys, this will be way down the road, but if I can get the manifold cheap I figure I can hold onto it. Joshie, I'll keep your notes handy for when I finally get there! Sincerely, Paul PS: Hoping to get my frame in the next few weeks to mount the engine in. PPS: What books would you recommend? |
Author: | kesteb [ Wed Jul 22, 2020 7:40 pm ] |
Will it be port fuel injected? If so, the answer is no. The base plate for a GM M90 will be too wide and there will be no room for the injectors on the runners. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
