Slant Six Forum https://slantsix.org/forum/ |
From naturally aspirated 225 to a boosted 170 https://slantsix.org/forum/viewtopic.php?f=30&t=66100 |
Author: | lgu32 [ Sat Jul 24, 2021 11:16 pm ] |
Post subject: | From naturally aspirated 225 to a boosted 170 |
Reformulated post: I like to have a cam suggestion for 170 cu in slant which will have sequential injection and stock compression. Boost estimation 0,5-0,7 bars. E85 fuel only. Behind of the 170 cu in slant will be 904 with high stall converter (3500+ with naturally aspirated 225) and 7,25" rear with 4,10 gears. <= These parts I will keep I have an Oregon cam with 236/230 (0,050") degrees. It has been surprisingly smooth in street use. If not better recommendations are come I will use it. But if a good turbo cam suggestion comes I will try it. Would be nice if it runs from 2000 up and the high power range is 3000-6000. |
Author: | lgu32 [ Sat Sep 04, 2021 6:25 am ] |
Post subject: | Re: From naturally aspirated 225 to a boosted 170 |
Monology continues: End of season. Plenty of 15s timeslips. Two times 15,3. A batch of 15,5-15,6 times. Worst was near 17 but it was fun ride. Slipping finally stopped at 3rd gear going on. 139.5 km/h at the end. 5500 rpm. Cast pistons. How much I can go up with 225? I tested my 225 today. Was running happily at 6500. Probably my cast pistons can do it every this and then. If I keep my 225 as is and add 0.4 bar boost I probably reach 13.6-13.8 time with 160 km/h trap speed @ 6300. This is my way to do it. I will order a t3/4 turbo and add it on this engine! |
Author: | Dart270 [ Mon Sep 06, 2021 4:35 am ] |
I keep my cast piston 225 engines at 6000 or below, but maybe you will be lucky? Thanks for the report and keep having fun!! Lou |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
