Slant Six Forum https://slantsix.org/forum/ |
35, 50, 75 wet Nitrous kit for Slant 6 https://slantsix.org/forum/viewtopic.php?f=30&t=66542 |
Author: | Valleyant [ Tue Apr 12, 2022 11:12 pm ] |
Post subject: | 35, 50, 75 wet Nitrous kit for Slant 6 |
I have a 1974 Plymouth Duster with a 198 and auto combination. I would like to try one of these kits for the drag strip. If I do, where is the best place to install the fuel/nitrous nozzle?......can I use an EGR block off plate and weld a bung on there for this? Thanks I want to add that this car is all stock with the 1945 Holley 1 barrel carb and intake and stock exhaust manifold. |
Author: | GTS225 [ Wed Apr 13, 2022 5:40 am ] |
Post subject: | Re: 35, 50, 75 wet Nitrous kit for Slant 6 |
Spraying in at the bottom of the plenum? I think not. Seems to me the airflow wouldn't mix it very well with the charge from the carb. That kind of thing leads to blown/burned engines. I suggest the proven method of a spray plate just under the throttle body of the carb. Roger |
Author: | slantzilla [ Wed Apr 13, 2022 7:45 am ] |
Doug used to spray on a 1bbl intake. IIRC, it was in the side of the plenum. Maybe he'll see this and chime in. |
Author: | Valleyant [ Thu Apr 14, 2022 6:10 pm ] |
I did see a picture online of a red one-barrel intake, looked to be aluminum, that had the Fuel and Nitrous solenoids mounted on it with the drilled/tapped threads for the nozzles. Gives me an idea for sure. Thanks |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
