It is currently Sun Oct 01, 2023 5:37 pm
Post new topic  Reply to topic  [ 581 posts ]  Go to page Previous 135 36 37 38 39
PostPosted: Fri Feb 10, 2023 9:02 am
Wow, glad everyone survived. Great job on the safety systems.
PostPosted: Fri Feb 10, 2023 10:18 am
I hate to see it like that.
I am glad that The Safety equipment worked properly. That sure is scary.
PostPosted: Fri Feb 10, 2023 10:46 am
Car Model: 1975 Dodge D100
I’m glad y’all are okay.
1975 Dodge D100 225 c.i., HEI, Parallel 2 bbl Motorcraft 2150, 904 auto, 9.25" 3.55:1
PostPosted: Fri Feb 10, 2023 10:47 am
Can the chassis be straightened on a frame machine?
PostPosted: Fri Feb 10, 2023 11:12 am
Thanks for posting, Rob. I am sure that was hard to do...
Yes, thanks to Toadracer and the whole team for the good times and memories. Thanks very much for your leadership, Rob. It was running great.
Frame rails are buckled and displaced about 8-10" to the pass side and upward maybe 4-6". Would require cutting off and welding in new frame rails, aligning everything... Better to start with a new chassis, IMHO. Everything inside the cage had relatively little damage.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Fri Feb 10, 2023 11:30 am
That's a shame. I know how much work, time and money go into building a race car.
PostPosted: Fri Feb 10, 2023 12:57 pm
If you guys want it. I'll donate my 64 signet, as a basis for a new car. It is just a body shell and needs the front clip sheet metal. I'll never build it.
66 Valiant Signet 225 nitrous
PostPosted: Sat Feb 11, 2023 7:29 am
Damn! That's disappointing to see, poor Toadracer, glad the Driver's OK. Make sure He gets a thorough checkup, I've taken some hard hits, the neck & shoulders are reminding Me of...if You're in need of scouts in the SW PA/WVA area, just give a shout, I'd be glad to run & check something out for You Guys..
PostPosted: Sat Feb 11, 2023 2:57 pm
Sorry to see it like that, guys. That was a fantastic car. Glad no one's physically hurt, though. At least it's nice to know the cage and everything else worked as intended.
Keep on keeping on!
Escape Velocity Racing
PostPosted: Thu Sep 07, 2023 9:52 pm
We saved what we could from the carnage. That roll cage Adam built did NOT want to come out, but we finally got it. I saved the only corner that survived for wall art. Adam got the trunk lid…
I found the perfect replacement for ToadRacer here in Tucson, AZ. Same year, color, trim, everything. It doesn’t even need new floors! :shock: I’m not sure if I’m up for it… it hasn’t sold yet… I might be procrastinating just long enough so that it sells and saves me the heartache…
Maybe ToadRacer will live again… some day… maybe…
71142388873__2C154FE4-B31D-4A1A-BBFB-3FEB805FE34B.jpeg [ 438.4 KiB | Viewed 283 times ]
Drag Racing
Commentator/
Points Keeper
PostPosted: Fri Sep 08, 2023 12:55 am
Hi Rob,
Thanks for the update. That is quite the picture of the Toadracer shell, lonely in the gravel lot/driveway. Thanks for everything you have done, and thanks to Adam too. I miss the team and the racing and the Toadracer. Someday...
Slant on, my friend.
