It is currently Fri Apr 19, 2024 2:00 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Wed May 11, 2022 7:36 pm
Rick Covalt wrote:
I suggest that you invest in a 10 cent cotter pin and drill a hole in that stud and pin that nut fast! :D :D
A good idea, but wouldn't of fixed our problem. Our air cleaner stud sheared both below the wingnut, and where it threads into the carb. The intermediate part was what went in the engine. :) Now we use a grade 8 stud, and also have the wheel weights taped on with metal tape.
PostPosted: Thu May 12, 2022 3:04 am
Ok Got it! That is a weird break! :D Must be all that power trying to get out. :D
PostPosted: Thu May 12, 2022 5:15 am
It seems that All kind of super goofy stuff happens in Road Racing that does not to Drag cars.
Imagine Drag racing for 60 Minutes at a time with no Letting off the gas..
Stuff has to be skookum, all the time and you will find faults with the smallest little things that will make your day and car slow down.
Kinda like plane mechanicals. it has to be better than good to last.
PostPosted: Thu May 12, 2022 5:39 am
We used to say a circle track engines running time in one race, is like drag engines running time in one season. For something like "Lemons" racing, multiply that by about 1,000.
Can you imagine a engine running at full load, and varying rpm for 16 hours?
66 Valiant Signet 225 nitrous
PostPosted: Thu May 12, 2022 7:16 am
I can imagine that Charlie!! And it’s SO MUCH FUN!!! :D :D :D
