Slant Six Forum https://slantsix.org/forum/ |
61 to 62 k frame swap https://slantsix.org/forum/viewtopic.php?f=43&t=65729 |
Author: | Greg Ondayko [ Sun Jan 24, 2021 2:50 pm ] |
Post subject: | 61 to 62 k frame swap |
Can a 61 valiant/ lancer k frame be swapped with a 62-66 k frame to use more standardized steering box and lower control arms? Thanks Sages, Greg |
Author: | hyper_pak [ Sun Jan 24, 2021 3:06 pm ] |
Post subject: | Re: 61 to 62 k frame swap |
Yes. Swap it all. There is a guy on FABO who changed the K but left his frame mount steering box. I don't think that was a good idea. |
Author: | Greg Ondayko [ Sun Jan 24, 2021 3:17 pm ] |
Okay. I figured that would be the case. I would not leave that saginaw? frame mount box if I did this swap. Greg |
Author: | Rob Simmons [ Sun Jan 24, 2021 3:20 pm ] |
Yep. Bolt in swap and nice to have the later steering box. |
Author: | hyper_pak [ Sun Jan 24, 2021 4:51 pm ] |
I think he had a rebuilt box, so wanted to keep it. I think you will have to change or modify the column. But it's a LOT better system. As you know just about unchanged till 1976. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
