Slant Six Forum https://slantsix.org/forum/ |
Vapor lock https://slantsix.org/forum/viewtopic.php?f=44&t=65675 |
Author: | CoyoteDan [ Wed Dec 30, 2020 8:21 pm ] |
Post subject: | Vapor lock |
Hello all, I have been getting this 74 Dodge D100 running and I am now struggling with vapor lock. I was told to put a fuel vapor separator in line between the fuel pump and carburetor but I am wondering if I can eliminate the charcoal canister and use the line that returns to the gas tank as a return line for the separator? The canister isn't being used anymore as the new carburetor doesn't have a vacuum nipple for it. Thank you! |
Author: | volaredon [ Thu Dec 31, 2020 5:37 pm ] |
Post subject: | Re: Vapor lock |
vapor lock in December? Not in this neck of the woods..... not sure where you are located.... but could it be something else? |
Author: | CoyoteDan [ Sat Jan 09, 2021 1:25 pm ] |
Southern California, the gasoline was boiling in the carburetor and but I think I figured the issue. The motor was running 100% water in the cooling system |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
