It is currently Fri Aug 12, 2022 2:42 am
PostPosted: Fri Feb 26, 2021 11:36 am
Hey Everyone,
Where is a good place to source a 5/16 Hard fuel line for a 66 Dart GT? Inline Tube seems to only cary a 3/8 line. I don't mind running that but then have to find a new fuel pick up and fuel pump to match. Unless you have a suggestion to run an adapter on the line. I just don't like the thought of possible fuel leaks.
"Your IQ test came back negative" - Murray F
66' Dart GT
66' Coronet 440 - 4 Door w/361
PostPosted: Fri Mar 12, 2021 1:32 pm
Ended up buying some 5/16 copper nickel tubing and bent my own up. Sure glad I did as the original fuel line was full of crud.
66' Dart GT
PostPosted: Sat Mar 13, 2021 4:58 am
Glad to hear that worked out. I always just get steel line and fittings from the parts store and bend it by hand. The usually have it in back but will let you go back and pick what you want.
Enjoy the Slanted driving!
"You mean you still have a Slant 6 in that thing?"
PostPosted: Sat Mar 13, 2021 8:38 am
That is the way to go! I love how easily it bends :D
12.80 @ 102.88
