Slant Six Forum https://slantsix.org/forum/ |
Broken Main Well Tube in Holley 1945 https://slantsix.org/forum/viewtopic.php?f=44&t=66081 |
Author: | emsvitil [ Mon Jul 12, 2021 10:03 pm ] |
Post subject: | Re: Broken Main Well Tube in Holley 1945 |
My idea is a one step smaller brass/copper tube that just fits inside...... |
Author: | matv91 [ Tue Jul 13, 2021 8:40 am ] |
https://www.carburetor-parts.com/holley ... parts.html |
Author: | matv91 [ Tue Jul 13, 2021 8:57 am ] | ||
Post subject: | Re: Broken Main Well Tube in Holley 1945 | ||
The 1940 and 1945 are much the same carb type
Author: | matv91 [ Tue Jul 13, 2021 9:05 am ] |
https://www.carburetor-parts.com/holley-17-92.html OD is correct . length maybe 1/4 inch too long. This might work,call mike see what he says. A better picture would help, air bleed holes have to be there can not be just solid tube. |
Author: | DaveB150 [ Tue Jul 13, 2021 9:19 am ] |
@emsvitil last night I was mulling over similar ideas. I found a lot of options for tiny brass tube stock online, a foot of a pretty similar diameter is only a few dollars, might be worth seeing if I can hold it gently enough in my drill press not to crush the tube and recreate it the best I can. Any idea how much I could mess up performance via having slight variations in well tube I.D.? I should be able to match drill diameter at least but I'll have to slightly increase tube size to maintain a press fit after drilling out the existing broken tube. @matv91 I scoured through carb-parts and another site, I think it was quadrajetparts.com, and both had an impressive selection of odds and ends that aren't covered in standard rebuild kits like pressed in vent tubes and whatnot but unfortunately I didn't see any replacements for this well tube on the 1945. I'll keep searching later, I would imagine someone has them for places who refurbish or a different model used the same thing. |
Author: | emsvitil [ Tue Jul 13, 2021 4:56 pm ] |
I don't see any problems if the ID area is greater than the area of the sum of the holes in the tube. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
