Slant Six Forum https://slantsix.org/forum/ |
Help with carb d150 not starting https://slantsix.org/forum/viewtopic.php?f=44&t=66085 |
Page 2 of 2 |
Author: | Slantsix83 [ Thu Jul 15, 2021 1:30 pm ] |
Post subject: | Re: Help with carb d150 not starting |
Reed wrote: Too much air? Do you mean a vacuum leak? It sounds like you need to adjust your choke, adjust your idle mixture, and check for vacuum leaks. It also sounds like you need to get a factory service manual for your vehicle and get the books listed in this thread: CLICK ME What should I focus on first choke idle air? |
Author: | Reed [ Thu Jul 15, 2021 2:09 pm ] |
Slantsix83 wrote: Reed wrote: Too much air? Do you mean a vacuum leak? It sounds like you need to adjust your choke, adjust your idle mixture, and check for vacuum leaks. It also sounds like you need to get a factory service manual for your vehicle and get the books listed in this thread: CLICK ME What should I focus on first choke idle air? All of it. Step one is to make sure all the settings on the carb are correct. If the choke and float level are correct, then start the engine and let it warm up. Once it is warmed up, check you idle speed, your idle mixture, and check for leaks. You have to do those last three all at once because they all affect each other. |
Author: | Slantsix83 [ Sat Jul 17, 2021 9:43 am ] |
Reed wrote: Slantsix83 wrote: Reed wrote: Too much air? Do you mean a vacuum leak? It sounds like you need to adjust your choke, adjust your idle mixture, and check for vacuum leaks. It also sounds like you need to get a factory service manual for your vehicle and get the books listed in this thread: CLICK ME What should I focus on first choke idle air? All of it. Step one is to make sure all the settings on the carb are correct. If the choke and float level are correct, then start the engine and let it warm up. Once it is warmed up, check you idle speed, your idle mixture, and check for leaks. You have to do those last three all at once because they all affect each other. I was able to get it running. Not perfect but ill keep adjusting. Thanks to everyone that helped |
Page 2 of 2 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
