It is currently Fri Jun 02, 2023 8:49 am
Post new topic  Reply to topic  [ 176 posts ]  Go to page Previous 18 9 10 11 12
PostPosted: Sat Jun 11, 2022 8:21 pm
On the Road Again
https://www.youtube.com/watch?v=rCd6wyGMmbU
a list of the bigger projects completed on the 68 B over the Winter 2021 and Spring 2022 months
* Installed Roller Rockers, B3 valve train optimization shims, new pushrods, installed
valve spring retainer bushings, modified the valve cover to accept the higher positioned valve train
* Installed Tuff Wheel and adapter
* Re built 8.75 differential with new 3:55 ring and pinion
* Installled a Wagner adjustable PCV and Moroso vapor catch can
* Built brackets and trim necessary to mount quad headlights and custom grill work.
I am quickly running out of reasons to not drive this car.
I had rolled the odometer back to zero, when I started this project. The odometer is currently setting on 260 miles.
It is a 'Go' from there.
I will post a few more photos of the projects listed.
PostPosted: Sat Jun 11, 2022 8:45 pm
The B3 rocker shaft shims significantly reduced the travel of the rocker rollers across the valve stem tip.
But they also moved the rocker shaft up over .200 and to make that work I needed new pushrods and a modified valve cover.
I added up lifts on the ends of the valve cover for clearance and moved the vapor containing baffles to the outside of the valve cover. To make a nicer flow of the PCV piping I swapped
PCV and air intake positions.
PostPosted: Sat Jun 11, 2022 8:49 pm
The goal of the new grill was to add an engine air intake, reminiscent of what was hot Rod stuff in the 60's and at the same time make it look like something Mopar could have done in 1968 and at the same time not do any changes that would impact re installing the original OE head lights and bezels.
This was an interesting project, and its done.
PostPosted: Sat Jun 11, 2022 8:54 pm
The OE steering wheel on this 68 Barracuda is just absolutely perfect. Has a nice shine, no cracks.
I am wanting to drive the car aggressively and I felt that a thicker steering wheel rim would give better
turning grip and at the same time I would not be stressing the nice OE steering wheel. I like the way the Tuff Wheel
looks and feels.
PostPosted: Sun Jun 12, 2022 5:53 am
Coolness on all that!
Drag Racing
Commentator/
Points Keeper
PostPosted: Sun Jun 12, 2022 6:18 am
Good job John!
PostPosted: Sat Jun 25, 2022 9:21 am
Been doing some local driving to run up a few break in miles and to establish the reliability of the car.
The photo below is of the car using it as a Grocery Getter. That day in the parking lot independently had two sets of folks approach me saying
"that car is just beautiful, what is it?"
I now have 330 miles on the car. The last trip was a 20 mile out and back, all highway. The fuel milage was 17.9 mpg on that stint.
Pulled the sparkplugs to do a compression test
the cranking pressure for 1 to 6 are
195, 190, 183, 190, 183, 185
I also adjusted the valves
I have the AF and VE tables adjusted good enough that the car starts and drives easily. No bogs or hesitations.
I think I can tune it a bit better for more performance and economy.
PostPosted: Sun Jun 26, 2022 10:24 am
Glad to hear you are driving the car around more. 18 MPG for 20 miles from a cold stop is very good, since it takes the car more than 10 min to warm up. I assume that is not all hwy miles too... I like those cranking compression numbers for pump premium too. Excellent work.
"You mean you still have a Slant 6 in that thing?"
PostPosted: Mon Jun 27, 2022 3:44 pm
Lou, thanks,
the calculated Static compression ratio is 10.67 and the dynamic compression is 8.37
no signs of pinging yet, but I know the fuel is a tad on the rich side and the timing curve is very conservative.
I plan to get back into the AF and VE tables soon.
PostPosted: Mon Jun 27, 2022 4:26 pm
Those numbers are very close to my 11.5 to 1 race engine. Mine are about 187-190#. Your car should run very well!! :D :D Congrats!
12.78 @ 103.7
PostPosted: Tue Jun 28, 2022 7:35 am
Thanks Rick,
you probably have a longer duration cam so it needs more static compression to overcome the bleed off ahead of IVC.
the cam I have in this motor is 254 @ .050
