It is currently Mon Jun 17, 2024 10:25 am
Post new topic  Reply to topic  [ 1015 posts ]  Go to page Previous 164 65 66 67 68
PostPosted: Tue May 21, 2024 6:08 am
Very cool to hear, Stan!! Congrats!
PostPosted: Tue May 21, 2024 5:45 pm
Here is a link to Sundays pass at Xtreme.
https://youtu.be/KjnpnRemI6I
PostPosted: Sun May 26, 2024 11:18 am
Oil changed, head retorqued, valves adjusted.
I have been going over the Weber carbs, couple of things to tweak.
They are such simple carburetors.
Making a heat shield between the bottom and the headers.
Looking at the AFR gage options, don't want to invest couple hundred bucks with something that will confuse.
Adding a low pressure oil light, after I get it installed I will run it thru a relay to do something other than let me know it's too late.
Need to get the clutch pedal out and weld the pivot hole smaller.
Still have some binding. I will put a bracket to return to top and rest on the bearing.
I found a lawn mower cam that looks interesting.
What do you think Slantzilla?
PostPosted: Sun May 26, 2024 11:22 am
Online
Looks like the next thing you could confuse yourself with. :mrgreen:
PostPosted: Sun May 26, 2024 12:26 pm
They are not confusing at all. I never remember to look at mine till I'm back in the pits. I plan to mount mine on the rear fender.
PostPosted: Sun May 26, 2024 1:22 pm
Maybe your review mirror as you drive out of their lives.
What I am reading and I know we have talked about this before, my short header extensions.
The sensor will be having a hard time reading and providing good data.
And the only one port is on the front 3 cylinders.
PostPosted: Sun May 26, 2024 1:41 pm
It will be accurate at full throttle.
PostPosted: Sun May 26, 2024 1:52 pm
Correct. I had mine in a 4 inch header ext. on one header. Only reads 3 cylinders but worked fine. I now run 12" extensions.
PostPosted: Mon May 27, 2024 4:35 am
hyper_pak wrote:
Will wrote:
Great News!!!!
Will
Thanks Will.
Do you think David will install my front struts now?
LOL
I think that he is worried about the historical value of the car.
Will
PostPosted: Mon May 27, 2024 8:25 am
Yea, I know.
Me too, but at this point that might not matter.
