Slant Six Forum https://slantsix.org/forum/ |
1968 Valiant Ruster Racer IRWIN PA https://slantsix.org/forum/viewtopic.php?f=6&t=36132 |
Page 84 of 84 |
Author: | Charrlie_S [ Thu May 23, 2024 4:50 am ] |
Post subject: | Re: 4-28-24 |
Greg Ondayko wrote: 4-28-24: I went to the local Test-n-Tune on Friday at the local Acceleration Testing Facility. All went well - Nothing surprising. It seems the car might be a bit faster on the 60' times by a few hundredths, and also the wider and taller slicks seems to have slowed down my MPH by ~4MPH from 111-112 to 108, not super happy about that. All 3 runs were in a pretty good headwind, so that might have something to do with it. I put down 2 1/4 Mile passes that were exactly the same so if anything, the taller / wider tires make things way more consistent somehow, or maybe that is just because they were brand new slicks?!??!! Greg, you really want to run the smallest slick that is consistent. On my old Mercury Cougar we had something like 13x32's originally. Couldn't get the car on my trailer with those tires, so had an old pair of 9x28's that we used just for transport. One day at the track it looked like rain so we didn't put on the big tires (didn't feel like changing tires in the rain). The car ran the best ET and MPH ever. Never put the big tires on the car again. PS: The cougar would 60 ft 1.58, 10.80's, 122 mph with the smaller tires. From a post on FABO Quote: 1970 Dodge Dart.All steel weight #3480 with driver.1974 360 engine pulled from Dodge van. Cylinder heads are J heads 1.88 valves with a basic valve job.still using the original valves that were installed at the factory.factory replacement 340 springs and factory non adjustable rockers Short block is .030 over with KB 107 flat tops 9.87 compression factory rods reconditioned with ARP bolts factory crank cut .010/.010 and balanced.727 trans. rev manual valve body 8-3/4 with 3.91 gears. Cam is Mopar purple shaft .509/292.Intake is Edelbrock TM-5 Carburetor is Holley 750 Double Pumper Fuel pump is Holley Blue Super stock springs 90/10 front shocks Car runs 11.79@113 on 26x8 slicks 11.99@111 on 28x10.5 Also when I ran 3/8 mile circle track, I was DQ one night for tires being too big (had to run street tire no larger then a certain size.) I put on a smaller tire (same dia, smaller width) and my lap times got quicker. Comes down to rolling resistance, and rotating mass. |
Author: | slantzilla [ Thu May 23, 2024 6:44 am ] |
Post subject: | Re: 1968 Valiant Ruster Racer IRWIN PA |
I did that at Clay City when I debuted the car. Did you know the needle on an Autometer mechanical gauge will go way past 260 and not break? Yeah, me neither. I always leave mine on. I has the dumbs sometimes. |
Page 84 of 84 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
