It is currently Thu Jan 21, 2021 6:25 am
PostPosted: Sun Nov 22, 2020 6:17 pm
Hello, Looking for a 65-67 B Body Rear end Housing. Pereferably within 3 Hours of Irwin PA.
Greg Ondayko
PostPosted: Sun Nov 22, 2020 10:02 pm
Car Model: 1964 Dart GT
Got one, but about 2900 miles away in San Jose Ca. Let me know if you may be interested.
PostPosted: Mon Nov 23, 2020 4:52 am
Car Model: '23 T-bucket
Hmmmm. A housing, by itself, (no axles or center section), shouldn't weight very much. A narrow pallet, some blocks and lag screws through the spring perches, and it would be shippable. Does Amtrak do freight?
Just a thought.....Roger
PostPosted: Mon Nov 23, 2020 5:22 am
Wha;t are you working on now?
Strive for Excellence, not Perfection.
PostPosted: Mon Nov 23, 2020 6:55 am
Grüne Hölle Dart.
The '69 B Body rear is a skosh too wide. - Tire rubbing is sometimes a bit much.. by my calculations going from the 68-70 B Rear housing to the 65-67 B Body Rear Housing will give me 3/8" More clearance per side.
I really don't want to get into cutting the wheel wells but May have to resort to it later.
The shipping from California would be more than the housing cost I am sure.
I have a few leads within 3 hours of here.
Greg Ondayko
PostPosted: Mon Nov 23, 2020 9:40 am
You don't want to look for an A body axle?
PostPosted: Mon Nov 23, 2020 9:42 am
Not really, Then I will be adding a bunch of spacer to make it work.
The b Body stuff is about $500-$800 Cheaper too.
Greg Ondayko
PostPosted: Mon Nov 23, 2020 4:29 pm
Hey Greg, you might have to call to see what year these are for.
https://pittsburgh.craigslist.org/pts/d/pittsburgh-mopar-body-rear-housing/7232826005.html
https://pittsburgh.craigslist.org/pts/d/washington-mopar-doge-or-plymouth-875/7234788908.html
PostPosted: Mon Nov 23, 2020 8:52 pm
Thanks matt,
I will have to look into those.
Greg Ondayko
PostPosted: Wed Nov 25, 2020 7:56 am
Car Model: '64 Valiant Convertible
Are there pictures or dimensions I can refer to? I have a housing of unknown origin....
Center to center on the spring perches? End to end of the flanges?
Whatever is available would be helpful.
Thanks for any help!
Neil
PostPosted: Wed Nov 25, 2020 8:37 am
Neil, Check this ...
https://www.forabodiesonly.com/mopar/th ... st.365494/
Greg Ondayko
PostPosted: Thu Nov 26, 2020 3:56 am
Part found.
Thanks All!
Greg Ondayko
