It is currently Tue Apr 20, 2021 5:55 am
PostPosted: Wed Apr 07, 2021 1:02 pm
I just pulled the timing cover off to replace the timing chain, and found no oil slinger on the crankshaft.
By my untrained eye, I would guess it came from the factory this way, as the rubber oil pan to timing cover gasket has bits of blue on it, beneath years of grease. Also the cam gear is the plastic covered style. Actually there is more paint on the rubber gasket than there is left on the engine.
Anyhow if anyone has the oil slinger, I am looking for one!
PostPosted: Wed Apr 07, 2021 5:59 pm
Try this from Amazon, It is Mopar P5249636
https://www.amazon.com/Crown-Automotive-J3173076-Oil-Slinger/dp/B009X1UT2G/ref=dp_prsubs_1?pd_rd_i=B009X1UT2G&psc=1
Strive for Excellence, not Perfection.
PostPosted: Thu Apr 08, 2021 4:41 am
Badvert65 wrote:
Magnificent! Thank You.
