It is currently Sat Jul 24, 2021 11:05 am
 Post subject: Clutch Pedal Push rod
PostPosted: Tue Jun 22, 2021 2:57 pm
Car Model: 86 dodge d100
I was wondering if anyone has a semi good clutch pedal push rod (goes from the pedal to z-bar) forsale for the A833OD. This would be for my 1986 dodge d100 slant six with the a833OD. I attached a pic with measurements for the one i currently have.
PostPosted: Wed Jun 23, 2021 11:17 am
Classic Industries has a clutch pedal push rod for a B body, if the length is different from that of a D150 one could always cut it and weld in the length needed, or a person with some metal working skills could weld up the eyes on the ends of your existing pushrod and file-machine it back into shape.
PostPosted: Wed Jun 23, 2021 11:23 am
You can take a look here to start:
http://www.brewersperformance.com/products.php?cat=35
and use dadtruck's suggestion to modify as needed.
Functionally they are all the same save for the length, so If you can final any 72-87ish D100-D300 at a local salvage yard you might be able to find one to fit your needs.
Greg Ondayko
PostPosted: Wed Jun 23, 2021 1:53 pm
Yeah i might have to piece one together and lengthen it as required. The one i have is pretty beat up from years of "abuse".
Thanks ill check it out. I tried brewers but they didnt have anything.
PostPosted: Thu Jun 24, 2021 11:17 am
3 Deuce Webber
Car Model: 78’ dodge D100 slant six
I would take it to a machine shop or pro welder. I had to make some shift linkage rods for a different vehicle I used to have. A better solution is to drill one side and have a pin cut on the other. Then it slides together and welded. A lot stronger than just welding. My 2 cents anyway.
PostPosted: Fri Jun 25, 2021 2:01 pm
Ya good point especially since its all mechanical linkage the extra strength would help.
