It is currently Thu Jan 20, 2022 1:12 pm
 Post subject: exhaust pipes?
PostPosted: Mon Jan 10, 2022 11:05 pm
Car Model: belvedere, barracuda
i need a ft pipe for a 64 B body. anybody have or know where to find?
 Post subject: Re: exhaust pipes?
PostPosted: Tue Jan 11, 2022 12:22 am
Try here https://www.accurateltd.com/
63 Plymouth Valiant Wagon
PostPosted: Tue Jan 11, 2022 3:28 am
Also if you cannot find a prebent pipe which accurate ltd should have .. many muffler shops can bend one up to fit your car... They also may have access to a bend card as well which should tell them what angle and length to bend the pipe for your application.
You can also get the individual bends / pieces and make it yourself if you are handy with a welder and tools.
PostPosted: Fri Jan 14, 2022 12:44 am
they don't list a slant six in a B body. only the A body. i have a huth bender and data cards but they don't give data on head pipes. just dual's for V-8. i guess they figuired welding on the flange would be to tough for the local mechanic back then??
PostPosted: Fri Jan 14, 2022 8:49 am
Car Model: '64 Valiant Convertible
Where about are you located?
You may find your neighbor is on this site, and will let you measure their car....
PostPosted: Fri Jan 14, 2022 5:31 pm
Kinda tough finding slant six B-body cars... the head pipe is not like the A body, but is more akin to the C-body...but slant 6 Fury's are like Rooster Specatcles...jest sayin...
PostPosted: Fri Jan 14, 2022 10:43 pm
actually there almost the same. i have a 69 cuda also. in storage of coarse. i used the B body pipe i did have a few years ago on it. it was a 2 piece. all i had to do to make it work on the a body was shorten where the 2 pieces met about 3 inches. and 1 bend just before the muffler. worse case i'll be waiting till spring so i can copy that. i'm hoping to not have to crawl on the floor too much as i have no lift. YET...
